Hello,
I’m wondering how (indoor) pipe lengths should be accounted for inbetween the supply and demand side nodes. If my understanding is correct, there needs to be a pipe object on the supply outlet and another pipe object on the demand inlet. Corresponding HVAC diagram:
Are these supposed to represent the same pipe segment (as with constructions between adjacent thermal zones the rule is to model the same construction twice, but in the corresponding reverse order), or are they separate?
If in reality the total segment would have a length of L, should both be modelled L=L1=L2, or L1=L/2 & L2=L/2 respectively?
Thanks!
