Hi All,
I want to programmatically add custom objects and fields in the OpenStudio IDD using the OpenStudio SDK (C# bindings). Is it possible?
Upon surfing the internet, it appears that in OpenStudio's C# API, we cannot modify the OpenStudio IddFile or its contained IddObjects directly (such as adding a new field to OS: Building) because OpenStudio's IddFile structure is considered read-only once loaded from disk.
However, when I edit the IDD file directly (through a text editor), I can read/retrieve the custom added objects and fields. This could be an alternative option!
Any advice on this would be greatly appreciated.
