The python measures within OpenStudio Application use the python 'standard library' that comes with the sofware. Located for example at C:\openstudioapplication-1.9.0\EnergyPlus\python_lib.
I would like to use non standard python packages, including ones I create to share common utility code between measures.
At the moment I have a very clunky approach - I basically copy my custom package into that location. It is horrible to develop and distribute this way.
Can I get OpenStudio application to look in other locations for python packages?
