Please see:
https://github.com/DamonHD/BuildingModelsForHeating/tree/main/ZonedHP/bungalow-2/20250624-dezoned-snapshot
bungalow-2-dezoned.idf is a simple bungalow with 4 equal size rooms/zones, with partitions between them.
At winter design day, flat/steady temperatures outside, heat loss is 1777W, less than expected.
I remove the partitions and merge the zones (bungalow-2-zoned-purchasedAir.idf), heat loss is now 2025W, more or less as expected.
Why the difference in heat loss when external surfaces and temperature/conditions are unchanged?
(I tried halving the partition wall thickness in case heat loss through contact area was different, but no change.)
