I am trying to obtain an annual summary of indoor illuminance results (such as the percentage of occupied hours with illuminance levels <300 lux, etc.) from DesignBuilder simulations for parametric analysis in jEPlus.
In OpenStudio, when using EnergyPlus daylighting controls and reference points, such illuminance metrics are available in the EnergyPlus output HTML (e.g., "% occupied hours below 300 lux" in the Annual Visual Resilience summary section). However, in DesignBuilder (I am using v6.0.1), even after enabling "All Summary Reports," I cannot find a similar Annual Visual Resilience summary in the output.
I understand that when using the Radiance engine in DesignBuilder for daylighting simulations, the results are not written to the EnergyPlus output HTML file, but rather to Radiance-specific reports. How can I configure DesignBuilder to generate the desired illuminance section ' Annual Visual Resilience summary in the EnergyPlus output HTML file — similar to what OpenStudio does — so that the results can be easily used for parametric analysis runs in jEPlus?
