I am working with a pre-built model sourced from NREL and am trying to collect specific data from the OpenStudio (OS) model for an Air Handling Unit (AHU). The parameters I need to extract include: Current Voltage Energy Temperature (air and water) Pressure Airflow Energy consumption However, from the simulation results, I can only access data for the following components: CORE_ZN PERIMETER_ZN_ (1-4) PSZ-AC (1-5) DesPer 1-17, including: Des Heat Mass Flow [kg/s] Des Heat Capacity [W] Des Cooling Mass Flow [kg/s] Des Sensible Cooling Capacity [W] Des Total Cooling Capacity [W] How can I access the additional parameters, such as current, voltage, and energy consumption, from the OpenStudio model for the AHU unit? here I'm sahring the drive link: https://drive.google.com/drive/folders/1Qpr68VQtbX3YWonu-IRc_uSmux80JRxI?usp=sharing
