EnergyPlus Fatal Error – Incomplete Day in Schedule:Compact (Generated via Python Script)
Hi everyone,
I’m trying to override surface temperatures in EnergyPlus using Schedule:Compact + EMS, generated from ENVI-met receptor data. I’ve scripted this in Python and created 288 Until: entries per day (5-min timestep) for each surface.
But when I run the simulation (E+ 24.1), I get this error for each surface:
* Severe * ProcessScheduleInput: ProcessIntervalFields, Processing time fields, incomplete day detected * ~~~ * ref Schedule:Compact="BATHROOM_0_FACE1_AIRTEMP_SCHEDULE" * Fatal * ProcessScheduleInput: Preceding Errors cause termination.
I’ve checked that:
Each schedule has exactly 288 entries (one per 5-minute step)
No missing values in the schedule
The formatting seems correct (e.g., “Until: 23:55, 24.0;” as the last line)
Any idea why EnergyPlus thinks the day is incomplete? Has anyone seen this when injecting schedules via script?
Thanks!
Hi everyone,
I’ve checked that:
Thanks!
