I want to model a structural column in OpenStudio. I usually create building geometry using FloorSpaceJS. To include the column, do I need to export the OSM file to SketchUp and add the column there? Could someone please explain the correct process? In my case, the column affects the building's daylighting and provides shading. However, when I tried adding the column in SketchUp, the wall behind it was not recognized as having an "outdoor" boundary condition. How can I address this issue properly?
