Hi—I’m using the Python API to control both the slat angles and the blind activation schedules. I’ve made sure to wait until the warm-up period ends before applying any actions or writing output, yet I still see a 20-day delay before the blinds respond. Temperature controls work immediately when I wait for warm-up period to apply, but the blind slats inexplicably take 20 days to move. i have this objects in order to have illuminance values : Daylighting:Controls, 108 DaylightingControls, !- Name 108, !- Zone or Space Name SplitFlux, !- Daylighting Method , !- Availability Schedule Name Continuous, !- Lighting Control Type 0.3, !- Minimum Input Power Fraction for Continuous or ContinuousOff Dimming Control 0.2, !- Minimum Light Output Fraction for Continuous or ContinuousOff Dimming Control 1, !- Number of Stepped Control Steps 1, !- Probability Lighting will be Reset When Needed in Manual Stepped Control Face 10, !- Glare Calculation Daylighting Reference Point Name 0, !- Glare Calculation Azimuth Angle of View Direction Clockwise from Zone y-Axis {deg} , !- Maximum Allowable Discomfort Glare Index , !- DElight Gridding Resolution {m2} Face 10, !- Daylighting Reference Point 1 Name 0, !- Fraction of Lights Controlled by Reference Point 1 ; !- Illuminance Setpoint at Reference Point 1 {lux}
!- =========== ALL OBJECTS IN CLASS: DAYLIGHTING:REFERENCEPOINT ===========
Daylighting:ReferencePoint, Face 10, !- Name 108, !- Zone or Space Name 2, !- X-Coordinate of Reference Point {m} -1, !- Y-Coordinate of Reference Point {m} 0.7; !- Z-Coordinate of Reference Point {m} and i have these schedues for the blind status and slat angle : ScheduleTypeLimits, BlindScheduleLimits, !- Name 0, !- Lower Limit Value 1, !- Upper Limit Value Discrete; !- Numeric Type
Schedule:Compact, Blind_Schedule, !- Name BlindScheduleLimits, !- Schedule Type Limits Name Through: 12/31, !- Field 1 For: AllDays, !- Field 2 Until: 24:00, 1; !- Value = “1” (blinds active) every t
ScheduleTypeLimits, SlatAngle, !- Name 0, !- Lower Limit Value 180, !- Upper Limit Value Continuous; !- Numeric Type
Schedule:Compact, SlatAngle_Manual, !- Nom du calendrier pour Face 7 SlatAngle, !- Type Through: 12/31, !- Toute l'année For: AllDays, !- Tous les jours Until: 24:00, 90; !- Angle 90° (ouvert)
WindowShadingControl, Zone1_Shading_Control, 108, 1, InteriorBlind, !- Changed to BLIND , !- Construction Name OnIfScheduleAllows, !- Control Type Blind_Schedule, !- Schedule Name , !- No setpoint Yes, !- Scheduled control No, VenetianBlind, !- Blind Material Name ScheduledSlatAngle, !- Slat Control Type SlatAngle_Manual, !- Slat Angle Schedule , , Group, Face 7_Combined;
as i said im using the python api to set the actuator values, and m using the last version (25.1)
