Has anyone found luck getting this to work? I successfully ran the measure and generated all the "user, baseline, and proposed" epjson, fianlout, and hourly jsons. However, in the create RPDs step, I get it translated, then the rct229 throws an error invalid_rmds[ruleset_model] = rmd_validation["errors"] KeyError: 'errors' Error: RCT evaluate failed: Command '['rct229', 'evaluate', '-f', '-rs', 'ashrae9012019', '-r', 'ASHRAE9012019DetailReport', '-rd', 'ruleset-checking-tool-master\example\output']' returned non-zero exit status 1.
