I am having an issue when running openstudio through the CLI where EnergyPlus can't find the schedule:file csv. I set the path in the .osw file using the "file_paths" parameter. However from the error message it appears EnergyPlus only searches the CWD and not any of the provided file_paths. I would expect Openstudio to pass the file_paths to EnergyPlus to use to find companion files. Is there another way to specify file_paths for EnergyPlus to search? Is this a bugy?
For context: I am generating an openstudio model (osm) and schedule file via buildstockbatch / ResStock / OS-HPXML. I then run a Python script to modify window and shading objects via the OS Python SDK, and then save the OSW. Then I call openstudio via the CLI: openstudio run --workflow test.osw. This creates a new run folder, which does not contain the schedule.csv file from the intial OS-HPXML measure, and I am adding the old run folder to the file_paths parameter.
EnergyPlus error message below:
** Severe ** Schedule:File="LIGHTING_INTERIOR", File Name: "in.schedules.csv" not found.
** ~~~ ** Paths searched:
** ~~~ ** Current Working Directory: "C:\Users\test\resstock\ds_test\run1\runx"
** ~~~ ** EnergyPlus Executable Directory: "c:\openstudio-3.9.0\EnergyPlus"
