Hello, I would need help with an HVAC system. As said in my question, I need help to configure a Controller:WaterCoil. I am using OpenStudio, so I have a visual part for my system. Logically, I have water coils in my system, and I need to control them depending on the air temperature needed.
My question is about the sensor node name : Does it refer to the temperature of the water flowing through my water coil, or does it refer to the temperature of the air to be modulated ? So do I refer to a setpoint in my plant loop or in my air loop ?
