Hi all,
I am hoping that you will be able to not only note that I am some kind of fool, but exactly what kind of fool I am, and how to be less so! B^>
I am trying to replicate a simplified form of the initial scenario from my paper:
https://www.mdpi.com/2071-1050/16/11/4710
a single-zone square bungalow (though 4 equal-size rooms will appear inside in due course) , no floor losses, roof and walls same U-value, no windows or ventilation losses or occupants or other incidental gains. With these values and equilibrium conditions:
IWL (Internal Wall Length) = 4m, thus whole external wall length 8m.
IWH (Internal Wall Height) = 2.3m
EWRU (Effective Wall and Roof U-value): 0.61 W/m2K
Wall and roof surface: (4x18.4m2 + 64m2) 137.6m2
Floor non-conducting
Interior and exterior temperatures at design conditions: 21C / -3C
I calculate in the paper and by hand:
Expected heat demand at design conditions: ~2000W
But the winter design day in the E+ model below shows ~1400W for several things in eplusout.eso, eg: ZONE ONE,Zone Predicted Sensible Load to Setpoint Heat Transfer Rate [W].
https://github.com/DamonHD/BuildingModelsForHeating/tree/main/ZonedHP/bungalow-1/20250407-snapshot
I am likely doing something very basic wrong for a 30% error!
You will see that I am a novice at E+, and that this is a work in progress, and that I may just be looking at the wrong things!
Any clues to point me in something like the right direction gratefully received!
Rgds
Damon
