CSV Schedules Not Appearing in Model Library Despite Correct Setup
I’m encountering an issue with my OpenStudio model where CSV-based schedule objects aren’t appearing in the model library—even though OpenStudio successfully reads the CSV files.
I am using this version of openstudio: 1.9.9+d1f890902a comiler: ninja: openstudio SDK (core) version: 3.9.0
What I've Tried: 1.Verified the handles and file paths manually in the .osm file. 2.Confirmed CSV files exist in the correct location. 3.Restarted OpenStudio and reloaded the model. 4.Checked the model library and ensured filters are cleared.
The problem: The schedule objects are not visible in the OpenStudio model library and cannot be assigned to components, even though they appear to be defined correctly and the files are accessible.
Are there additional steps needed/solutions to make CSV schedules appear in the model?
