I am having this error "Energy returned a non-zero exit code (1). Check the stdout-energyplus log" (see text below). Can it be the version of openstudio and energyplus not compatible? I have 24.2.0 energyplus and 1.8.0 openstudio.
This is what's coming from openstudio run simulation:
Starting EnergyPlus Simulation. EnergyPlus executable path is C:/openstudioapplication-1.8.0/EnergyPlus/energyplus.exe ExpandObjects executable path is C:/openstudioapplication-1.8.0/EnergyPlus/ExpandObjects.exe Starting simulation in run directory: C:/Users/tiago/AppData/Local/Temp/osmodel-7798-c8d0-e904-1edc-1743157435-0/resources/run Running command '"C:/openstudioapplication-1.8.0\EnergyPlus\ExpandObjects.exe"' ExpandObjects Started. No expanded file generated. ExpandObjects Finished. Time: 0.062 Running command '"C:/openstudioapplication-1.8.0\EnergyPlus\energyplus.exe" in.idf' EnergyPlus Starting EnergyPlus, Version 24.1.0-9d7789a3ac, YMD=2025.03.28 18:40 Adjusting Air System Sizing Adjusting Standard 62.1 Ventilation Sizing Initializing Simulation Program terminated: EnergyPlus Terminated--Error(s) Detected. EnergyPlus returned '1' EnergyPlus returned a non-zero exit code (1). Check the stdout-energyplus log Removing any copied EnergyPlus files EnergyPlus Terminated with a Fatal Error. Check eplusout.err log. Found error in state 'EnergyPlus' with message: 'D:\OSN\Openstudio\src\workflow\RunEnergyPlus.cpp@311 : EnergyPlus Terminated with a Fatal Error. Check eplusout.err log.' stderr: Failed to run workflow. Last Error: stderr: Found error in state 'EnergyPlus' with message: 'D:\OSN\Openstudio\src\workflow\RunEnergyPlus.cpp@311 : EnergyPlus Terminated with a Fatal Error. Check eplusout.err log.' Simulation failed to run, with exit code 1
