Blinds layer position
image descriptionHi,
I have run into a problem with E+ recently when trying to model a CCF(closed cavity facade) with blinds. I found out that I can only put blinds only between the inner two glass layers for (between glass shade/blind).
I tried to use WINDOWS to create IDF file but WINDOW doesn't allow to export IDF file with blinds.
Is there any other way around this?
Hi,
Hi,
image descriptionimage description
Hi,
Hi,
