I am modeling a rooftop package unit in Openstudio and noticed that when using a two speed DX cooling coil it causes the air loop details section of the Openstudio results to be skipped.
"Air Loops Detail section failed and was skipped because: undefined method `each' for nil:NilClass. Detail on error is in Measure Warnings section, if enabled at the bottom of this report."
"Air Loops Detail section failed and was skipped because: undefined method `each' for nil:NilClass."
Any Idea on how to prevent this?
