Help With Custom Schedule From File
I've loaded a schedule in from a csv file through the Schedule File tab on Other Schedules under Schedules. However, when I go to add it to the load under the loads tab, I cannot find it in the available schedules list. I made sure to save the csv in the same directory as the osm and put the file into the generated output files once I saved my osm file as well.
Any idea on where I need to go to find it or what I might be doing wrong?
