Hi All,
I'm tring to incorporate an artificial time lag into my simulation, using the EMS. I have a CRAH unit in a data centre and I want the CRAH unit to supply airflow with a delay of 6 time steps from the zone cooling demand sensing. The cooling is controoled via a SetpointManager:SingleZone:Cooling. I am not getting any time lag at all and the CRAH unit rumps up as normal with the increase of the zone cooling demand.
Any thoughts on what I need to ammend to incorporate a time lag? See below my EMS setup.
EnergyManagementSystem:Sensor, Energy_Management_System_Sensor_1, !- Name DC, !- Output:Variable or Output:Meter Index Key Name Zone Predicted Sensible Load to Cooling Setpoint Heat Transfer Rate; !- Output:Variable or Output:Meter Name
EnergyManagementSystem:Actuator, Energy_Management_System_Actuator_1, !- Name Var Spd Fan, !- Actuated Component Unique Name Fan, !- Actuated Component Type Fan Air Mass Flow Rate; !- Actuated Component Control Type
EnergyManagementSystem:Actuator, Energy_Management_System_Actuator_2, !- Name Node 4, !- Actuated Component Unique Name System Node Setpoint, !- Actuated Component Type Mass Flow Rate Setpoint; !- Actuated Component Control Type
EnergyManagementSystem:TrendVariable, FanFlowDemand_Trend, !- Name Energy_Management_System_Sensor_1, !- EMS Variable Name 10; !- Number of Timesteps to be Logged
EnergyManagementSystem:Program, DelayedFanControl, SET Energy_Management_System_Actuator_2 = @TrendValue(FanFlowDemand_Trend 10);
EnergyManagementSystem:ProgramCallingManager, RunDelayedFanControl, BeginTimestepBeforePredictor, DelayedFanControl;
