VRF coils in VAV air terminal
Is there a way in EnergyPlus (or DesignBuilder) to model VRF coils connected to a VRF Outdoor Unit in a VAV air terminal in a zone?
The only way I found to model something similar is by using a VRF Indoor Unit, but the unit has fans and isn't directly connected to my rooftop unit, which preconditions the air.
Is there a way in EnergyPlus (or DesignBuilder) to model VRF coils connected to a VRF Outdoor Unit in a VAV air terminal in a zone?terminal?
The only way I found to model something similar is by using a VRF Indoor Unit, but the unit has fans a fan and isn't directly connected to my rooftop unit, which preconditions I need to precondition the air.
Is there a way in EnergyPlus (or DesignBuilder) to model VRF coils connected to a VRF Outdoor Unit in a VAV air terminal?
The only way I found to model something similar is by using a VRF Indoor Unit, but the unit has a fan and isn't directly connected to my rooftop unit, which I need to precondition the air.
