How to resolve gross_rated_sensible_heat_ratio error of EnergyPlus measures in OpenStudio
Hello to the entire community,
I have modeled a split air conditioner in a single zone using OpenStudio. I downloaded the fault models from the NREL site to analyze their impact.
For cases using "EnergyPlus measures" (like condenser fouling, PresenceOfNonCondensable, LiquidLineRestriction), the simulation has failed, and eplusout.err displays the following error:
<root>[Coil:Cooling:DX:SingleSpeed][1 Spd DX Clg Coil 7][gross_rated_sensible_heat_ratio] - Value type "string" for input "NaN" not permitted by 'type' constraint. Failed to validate against child schema #0, "NaN" - Failed to match against any enum values. Failed to validate against any schemas allowed by the anyOf constraint.
I am trying to locate gross_rated_sensible_heat_ratio in the HVAC settings to assign a value, but I cannot find it.
I have modeled a split Split air conditioner in a single zone using OpenStudio. I downloaded the fault models from the NREL site to analyze their impact.
I am trying to locate defined the gross_rated_sensible_heat_ratiorated_sensible_heat_ratio in value as 0.75, but the HVAC settings to assign a value, but I cannot find it.error persists.
