Hi!
I am working on a Service Hot Water loop and have added a Water Use Equipment object to the Water Use Connection in the loop. I selected the space for the Water Use Equipment in the HVAC Systems tab, but I don't see the equipment connected to the space in the Spaces tab.
I'm wondering if this is expected behavior, or if I'm missing a step to properly connect the Water Use Equipment to the space.
