Hello, I've been running several ResStock models using OpenStudio-HPXML and noticed that the default zone temperature capacitance multiplier is set to 7. Could someone point me to any reference or documentation that explains the rationale behind this value? @shorowit
I also tested the 'InternalMass' parameter, it seems like the zone temperature is more sensitive to 'ZoneCapacitanceMultiplier:ResearchSpecial', the internal mass parameter did not make much impact, could anyone share their thoughts on this?
Thank you!
