Hi,
I previously installed and used PAT 3.7 without any problem. I recently installed PAT 3.9, but I couldn't start local server. I used the following start server command in cmd:
"C:\ParametricAnalysisTool-3.9.0\pat\ruby\bin\ruby.exe" "C:\ParametricAnalysisTool-3.9.0\pat\OpenStudio-server\bin\openstudio_meta" start_local --worker-number=7 --energyplus-exe-path="C:\ParametricAnalysisTool-3.9.0\pat\EnergyPlus\energyplus.exe" --openstudio-exe-path="C:\ParametricAnalysisTool-3.9.0\pat\OpenStudio\bin\openstudio.exe" --ruby-lib-path="C:\ParametricAnalysisTool-3.9.0\pat\OpenStudio\Ruby" --mongo-dir="C:\ParametricAnalysisTool-3.9.0\pat\mongo\bin" --debug "C:\Users\<user name>\PAT\test”
and I've got the following 'rails.log'
C:/ParametricAnalysisTool-3.9.0/pat/OpenStudio-server/gems/gems/bundler-2.4.10/lib/bundler/definition.rb:524:in `materialize': Could not find date-3.3.4, sassc-2.4.0, bson-4.14.1, msgpack-1.4.5, nio4r-2.5.9, websocket-driver-0.7.6, json-2.7.2 in locally installed gems (Bundler::GemNotFound)
from C:/ParametricAnalysisTool-3.9.0/pat/OpenStudio-server/gems/gems/bundler-2.4.10/lib/bundler/definition.rb:197:in `specs'
from C:/ParametricAnalysisTool-3.9.0/pat/OpenStudio-server/gems/gems/bundler-2.4.10/lib/bundler/definition.rb:254:in `specs_for'
from C:/ParametricAnalysisTool-3.9.0/pat/OpenStudio-server/gems/gems/bundler-2.4.10/lib/bundler/runtime.rb:18:in `setup'
from C:/ParametricAnalysisTool-3.9.0/pat/OpenStudio-server/gems/gems/bundler-2.4.10/lib/bundler.rb:171:in `setup'
from C:/ParametricAnalysisTool-3.9.0/pat/OpenStudio-server/gems/gems/bundler-2.4.10/lib/bundler/setup.rb:23:in `block in <top (required)>'
from C:/ParametricAnalysisTool-3.9.0/pat/OpenStudio-server/gems/gems/bundler-2.4.10/lib/bundler/ui/shell.rb:159:in `with_level'
from C:/ParametricAnalysisTool-3.9.0/pat/OpenStudio-server/gems/gems/bundler-2.4.10/lib/bundler/ui/shell.rb:111:in `silence'
from C:/ParametricAnalysisTool-3.9.0/pat/OpenStudio-server/gems/gems/bundler-2.4.10/lib/bundler/setup.rb:23:in `<top (required)>'
from <internal:C:/ParametricAnalysisTool-3.9.0/pat/ruby/lib/ruby/3.2.0/rubygems/core_ext/kernel_require.rb>:85:in `require'
from C:/ParametricAnalysisTool-3.9.0/pat/ruby/lib/ruby/3.2.0/rubygems.rb:1370:in `<top (required)>'
from <internal:gem_prelude>:2:in `require'
from <internal:gem_prelude>:2:in `<internal:gem_prelude>'
I checked the installed folder, and found out all the gems were existed.
What might be the problem?
Might be an interfere from previous version installed? If this is the case, what can I do to resolve this?
Any help would appreciated.
