Openstudio is providing different results for the same model
I am building an energy model in Openstudio to help calculate energy savings. I noticed something was off with the results I was getting with some measures. I went back and noticed that if I run the same model, I got three different results running the exact same model without making changes. The results I am specifically referring to are the annual gas and electric consumption as well as District cooling consumption. I know that this didn't used to be an issue with previous models. Is there a setting or something that i could have accidentally changed?
