How to Control Twospeed heat pump using actuator?
I want to control an air-source two-speed heat pump using Python. Specifically, I would like to control the compressor staging or coil speed in real-time using the Python API. How can I implement this?
I am using the following handles to get and set values:
I am using the following handles to get and set values: python dx_coil_speed_var_handle = data_transfer.get_variable_handle(state, "Unitary System DX Coil Speed Level", "TWOSPEED HEAT PUMP 1")
cooling_setpoint_handle = data_transfer.get_actuator_handle(state, "Coil Speed Control", "TWOSPEED HEAT PUMP 1", "Unitary System DX Coil Speed Value") I am defining a callback function using the API like this:
python api.runtime.callback_inside_system_iteration_loop(state, callback_function) Could you provide guidance or an example of how to implement this?
python
1")
python
