i run my openstudio model. The error show controller error for controller = "pau-b1-02 controller chw clg coil. I don't know how to fix the problem and need help
FindRootSimpleController: Controller error for controller = "PAU-B1-02 CONTROLLER CHW CLG COIL" * ~~~ * Environment=SHENZHEN ANN HTG 99.6% CONDNS DB, at Simulation time=01/21 06:00 - 06:10 * ~~~ * Controller function is inconsistent with user specified controller action = Reverse action * ~~~ * Actuator will be set to maximum action * ~~~ * Controller control type=Temperature * ~~~ * Controller temperature setpoint = -19.28 [C] * ~~~ * Controller sensed temperature = 6.98 [C] * ~~~ * Controller actuator mass flow rate set to 6.68 [kg/s] * ~~~ * Controller actuator temperature = 7.00 [C] * ~~~ * Note: Chilled water coils should be reverse action and the entering chilled * ~~~ * water temperature (controller actuator temperature) should be below the setpoint temperature * ~~~ * Note: Hot water coils should be normal action and the entering hot * ~~~ * water temperature (controller actuator temperature) should be above the setpoint temperature * Warning * SolveAirLoopControllers: Maximum iterations (50) exceeded for PAU-M-02, at RUN PERIOD 1, 05/25 17:20 - 17:30 * Warning * SolveAirLoopControllers: Maximum iterations (50) exceeded for PAU-M-01, at RUN PERIOD 1, 06/05 17:23 - 17:25 * Warning * SolveAirLoopControllers: Maximum iterations (50) exceeded for PAU-B1-11, at RUN PERIOD 1, 06/16 23:04 - 23:05 * Warning * SolveAirLoopControllers: Maximum iterations (50) exceeded for PAU-B1-11, at RUN PERIOD 1, 07/02 14:17 - 14:18 * Warning * SolveAirLoopControllers: Maximum iterations (50) exceeded for PAU-04-02, at RUN PERIOD 1, 07/02 18:10 - 18:11 * Warning * SolveAirLoopControllers: Maximum iterations (50) exceeded for PAU-04-02, at RUN PERIOD 1, 07/09 23:14 - 23:16 * Warning * SolveAirLoopControllers: Maximum iterations (50) exceeded for PAU-M-02, at RUN PERIOD 1, 07/27 10:20 - 10:30 * Warning * SolveAirLoopControllers: Maximum iterations (50) exceeded for PAU-B1-11, at RUN PERIOD 1, 08/02 15:26 - 15:28 * Warning * SolveAirLoopControllers: Maximum iterations (50) exceeded for PAU-M-01, at RUN PERIOD 1, 08/05 15:20 - 15:23 * Warning * SolveAirLoopControllers: Maximum iterations (50) exceeded for PAU-M-02, at RUN PERIOD 1, 08/05 15:20 - 15:23 * Warning * SolveAirLoopControllers: Maximum iterations (50) exceeded for PAU-M-02, at RUN PERIOD 1, 08/05 15:28 - 15:30 * Warning * SolveAirLoopControllers: Maximum iterations (50) exceeded for PAU-M-01, at RUN PERIOD 1, 08/06 12:20 - 12:30 * Warning * SolveAirLoopControllers: Maximum iterations (50) exceeded for PAU-M-02, at RUN PERIOD 1, 08/06 12:27 - 12:30 * Warning * SolveAirLoopControllers: Maximum iterations (50) exceeded for PAU-M-02, at RUN PERIOD 1, 08/06 17:30 - 17:33
Error message below:
 *   ~~~   * **   ~~~   **  Environment=SHENZHEN ANN HTG 99.6% CONDNS DB, at Simulation time=01/21 06:00 - 06:10
 *   ~~~   * **   ~~~   **   Controller function is inconsistent with user specified controller action = Reverse action
 *   ~~~   * **   ~~~   **   Actuator will be set to maximum action
 *   ~~~   * **   ~~~   ** Controller control type=Temperature
 *   ~~~   * **   ~~~   ** Controller temperature setpoint = -19.28 [C]
 *   ~~~   * **   ~~~   ** Controller sensed temperature = 6.98 [C]
 *   ~~~   * **   ~~~   ** Controller actuator mass flow rate set to 6.68 [kg/s]
 *   ~~~   * **   ~~~   ** Controller actuator temperature = 7.00 [C]
 *   ~~~   * **   ~~~   **   Note: Chilled water coils should be reverse action and the entering chilled
 *   ~~~   * **   ~~~   **         water temperature (controller actuator temperature) should be below the setpoint temperature
 *   ~~~   * **   ~~~   **   Note: Hot water coils should be normal action and the entering hot
 *   ~~~   * **   ~~~   **         water temperature (controller actuator temperature) should be above the setpoint temperature
 * Warning * ** Warning ** SolveAirLoopControllers: Maximum iterations (50) exceeded for PAU-M-02, at RUN PERIOD 1, 05/25 17:20 - 17:30
 * Warning * ** Warning ** SolveAirLoopControllers: Maximum iterations (50) exceeded for PAU-M-01, at RUN PERIOD 1, 06/05 17:23 - 17:25
 * Warning * ** Warning ** SolveAirLoopControllers: Maximum iterations (50) exceeded for PAU-B1-11, at RUN PERIOD 1, 06/16 23:04 - 23:05
 * Warning * ** Warning ** SolveAirLoopControllers: Maximum iterations (50) exceeded for PAU-B1-11, at RUN PERIOD 1, 07/02 14:17 - 14:18
 * Warning * ** Warning ** SolveAirLoopControllers: Maximum iterations (50) exceeded for PAU-04-02, at RUN PERIOD 1, 07/02 18:10 - 18:11
 * Warning * ** Warning ** SolveAirLoopControllers: Maximum iterations (50) exceeded for PAU-04-02, at RUN PERIOD 1, 07/09 23:14 - 23:16
 * Warning * ** Warning ** SolveAirLoopControllers: Maximum iterations (50) exceeded for PAU-M-02, at RUN PERIOD 1, 07/27 10:20 - 10:30
 * Warning * ** Warning ** SolveAirLoopControllers: Maximum iterations (50) exceeded for PAU-B1-11, at RUN PERIOD 1, 08/02 15:26 - 15:28
 * Warning * ** Warning ** SolveAirLoopControllers: Maximum iterations (50) exceeded for PAU-M-01, at RUN PERIOD 1, 08/05 15:20 - 15:23
 * Warning * ** Warning ** SolveAirLoopControllers: Maximum iterations (50) exceeded for PAU-M-02, at RUN PERIOD 1, 08/05 15:20 - 15:23
 * Warning * ** Warning ** SolveAirLoopControllers: Maximum iterations (50) exceeded for PAU-M-02, at RUN PERIOD 1, 08/05 15:28 - 15:30
 * Warning * ** Warning ** SolveAirLoopControllers: Maximum iterations (50) exceeded for PAU-M-01, at RUN PERIOD 1, 08/06 12:20 - 12:30
 * Warning * ** Warning ** SolveAirLoopControllers: Maximum iterations (50) exceeded for PAU-M-02, at RUN PERIOD 1, 08/06 12:27 - 12:30
 * Warning * ** Warning ** SolveAirLoopControllers: Maximum iterations (50) exceeded for PAU-M-02, at RUN PERIOD 1, 08/06 17:30 - 17:3317:33
Thanks
Thanks
