OpenStudio workflow not producing in.json however Eplus does
When I run an OpenStudio workflow the in.json in.json is not produced in the run directory,
however, upon running the .idf .idf file in the run directory with EPlaunch the in.json file is produced.
The Output:JSON object is present in both in the .osm and idf and is set to Yes, so I would expect that the in.json is produced in the openstudio workflow.
I also tried the debug flag of the OpenStudio CLI to no avail.
I am unable to determine why this is happening.
OpenStudio version is 3.9.0 if that is helpful
Any insights would be appreciated!
