DVIEW The following units failed to be converted: lum/W
Not able to use DView with OpenStudio because of this error. DVIEW The following units failed to be converted: lum/W. I tried the latest versions I can find but they don't seem to have the patch that was apparently done about a year ago. I'm not able to reubuild the entire WEX library. Are there any alternative solutions to this issue? Is DView rendered unusable now from within OpenStudio? Thanks
