Hello,
I believe that it is possible to run an Open Studio workflow where just the measures are applied and EnergyPlus doesn't simulate.
If this is possible, what argument do I place in the OpenStudio workflow to make this happen?
Thank you
| 1 | initial version |
Hello,
Thank you
| 2 | retagged |
Hello,
Thank you
Hello,
If I am applying this is possible, what argument do I place to the OpenStudio workflow.
"no_simulation":"true",
However in the OpenStudio workflow WorkflowRunOptions, no_simulation is still set to make this happen?false and the simulation still runs.
What could I be doing wrong?
Thank you
Hello,
I am applying this argument to the OpenStudio workflow.
However in the WorkflowRunOptions, no_simulation is still set to false and the simulation still runs.
Thank you
