Hello! I been trying to install the OpenStudio Sketchup plugin for a week now and I haven't been able to make it work. I first downloaded Sketch Up 2024 (last version). Then I downloaded the OpenStudioApplication 1.8.0 version (latest). Finally, I've tried installing the OpenStudio plugin: 1. Manually downloading the latest version of it form https://github.com/openstudiocoalition/openstudio-sketchup-plugin/releases 2. Through the SketchUp Extension Warehouse The errors i have had are the following: - First, nothing changed and when I closed the application and restarted it again, when I tried to open a new file it just automatically closed the app. - Then I managed to install the plugin, it said it was correctly signed, but then i couldn't find the OpenStudio toolbox anywhere (in the extension manager it said that the plugin was correctly signed and activated) - Then I tried installing earlier versions of the Openstudio App (the 1.7.0 and the 1.6.0) and earlier versions of the plugin and these errors appeared:
Now I'm at the point where if I open SketchUp, it stays blank for a few seconds, then a smaller page appears with this title: OpenStudio Inspector for less than a second, and finally, it basically closes the entire SketchUp app.
I have no idea of what to do next... I would appreciate a little bit of help. Thank you very much!
