I have a basement depth of ~10 m; however, when entering a BaseDepth that is above ~7.4 m the simulation crashes due to the following error:
* Severe * Output:PreprocessorMessage="GroundTempCalc - Basement" has the following Severe conditions: * ~~~ * EPlusOutput: Calculations have resulted in invalid results (NAN). (Could be divide by zero. * ~~~ * Overflows. Other causes.) Check Input Parameters. Hint: Start from defaults for each object * ~~~ * and work forward. * Severe * Output:PreprocessorMessage="GroundTempCalc - Basement" has the following Fatal condition: * ~~~ * Program terminates due to preceding condition(s). * Fatal * Preprocessor condition(s) cause termination.
I have tested other variables, but this one seems to be the one causing issues, even though the programme states that this input has no maximum. Does anyone know what the issue could be?
