Simulation Openstudio never finishes and gets stuck
Since I created a loop in OpenStudio to represent a gas heating system with water radiators in each room of the apartments. When I run the simulation, it never finishes and gets stuck. Do you have a solution to unblock my situation? (I left the simulation running overnight with no result)
Since I created a loop in OpenStudio to represent a gas heating system with water radiators in each room of the apartments. When I run the simulation, it never finishes and gets stuck. Do you have a solution to unblock my situation? (I left the simulation running overnight with no result)link text
