I'm trying to compare the energy outputs of cooling air using a 100% Outdoor AHU connected to an air cooled chiller. I'm trying to compare a simplistic enthlpy calculation where i use the dry bulb RH and set-point to get the enthalpy difference and than divide it by the COP which is assumed to be at constant value of 3.1.
I found a 20% difference from the EnergyPlus output where my calculation is lower. In both models i assumed a set-point of 18C, constant CFM and use the same weather file (mainly dry ball temp and RH values)
I can also tell that the enthalpy calculation is more sensitive to change at high temperatures and is less accurate there.I'm trying to think where is this change in results is coming from, maybe from using a constant cop? but 20% is a lot i would expect less. anyway any insights will be welcomed
I'm adding an HTML of the graph compering both models
