I'm running a model using the NewEnvelopeAndLighting compliance type to test the geometry and am getting the following error. The model does not have any HVAC systems and certainly doesn't have solar hot water so I'm at a loss for why a solar fraction error is occurring.
Error: Retrieving data from model 0 (invalid FluidSys property type (USER model, class 43, property type 2, iError 0)) in GetBEMProcData() evaluating rule: Set SIZING_PROPOSED FluidSys:AnnualSolFrac (80:'HVACPrimary-General.rule' line 857)
The rule file block from the error message, line 857 is SIZING PROPOSED.
// ---------- Annual Solar Fraction for Water Heaters --------------
RULE FluidSys:AnnualSolFrac
DESCRIPTION
"This Annual Solar Fraction used for Water Heaters."
HELP
REFERENCE
ACM-5.9.1 Water Heating
INPUTCLASS
Optional
MINIMUM
MAXIMUM
DEFAULT
if( FluidSys:Type = "ServiceHotWater" )
then 0
else UNDEFINED
endif
SIZING_PROPOSED
if( u:FluidSys:Type = "ServiceHotWater" )
then u:AnnualSolFrac
else UNDEFINED
endif
SIZING_BASELINE
UNDEFINED
ANNUAL
z:AnnualSolFrac
ENDRULE
