Hello everyone, Is it possible for E+ to calculate zone sensible heat gain from the construction alone without HVAC system. If possible which output should I request? Right Now I can only request: Surface Average Face Conduction Heat Gain Rate [W] . My objective is to find Max air flow rate to use in the HVAC Template:IdealLoadAirSystem
Thanks in advance. Here is my model https://drive.google.com/drive/folders/1DvtvjGtFOMiaKulCSxTiHy4BcglUUyos?usp=sharing
