Two Rated capacities of the same chiller is reported in the E+ tabular report (I'm not qualified to upload figure).
The 1st one is under Report: Equipment summary / For Facility / Central Plant
Type Reference Capacity [W] Reference Efficiency [W/W] Rated Capacity [W]
CHILLER ELECTRIC EIR 1 Chiller:Electric:EIR 1540500.38 2.93 1537481.56
Note the Reference capacity is slightly different from Rated Capacity.
However, the 2nd one under [The same Report] / chillers shows the same value.
Type Reference Capacity[W] Reference Efficiency [W/W] Rated Capacity [W]
CHILLER ELECTRIC EIR 1 Chiller:Electric:EIR 1540500.38 2.93 1540500.38
The chiller reference capacity is autosized.
I tried to find out how is Rated Capacity calculated by E+, but failed. (The source code is quite complex) Anyway, we may focused on the Reference Capacity, which is well explained by the Input Output Reference. If some could explain how the 1st Rated Capacity is calculated, it is helpful.
