Hello. We conducted simulations using DOAS and VRF systems. However, I am asking a question because I have the following error and cannot find a solution even after adjusting the coil capacity.
Severe * Developer Error: sizing of Gross Rated Sensible Heat Ratio failed. * ~~~ * Occurs in Coil:Cooling:DX:VariableRefrigerantFlow VRF ZONE TERMINAL COOLING COIL 3 * Severe ** Sizing: Coil:Cooling:DX:VariableRefrigerantFlow VRF ZONE TERMINAL COOLING COIL 3 has zero rated air flow rate
I have attached the IDF file and errors to the link below! idf file: https://drive.google.com/file/d/1y0ZYx30EufLXOeySCD1L1KiC2T0_zWVi/view error file: https://drive.google.com/file/d/1RyFoxd87pQ9Y0ntR7C6JmgzFCPoyhNVz/view
Plzzzzzzzzzzzzzz. help me
