Hello everyone,
I am trying to do the simulation with contain both of OAU and FCU into 1 room. So, I adapted to use the HVAC air loop for FCU then the UnitVentilator use for the OAU. In this case i found problem that cooling coil water of the UnitVentilator do not show any cooling load.
One more question, is it possible to control room dewpoint by changing the working condition only from that UnitVentilator
Thank you so much., i have attach the like for my idf: link text
