I'm trying to just setup OpenStudio on ubuntu24.04 i installed it and i tried to open a whole building measure for whole building -CreateTypicalBuilding when i try
i just downloaded Open-Studio SDK =3.8.0 Version=1.8.0+2722e3e751
clicked on find measures and downloaded the said measure. after that i clicked apply measure choose the said measure and as input entered Geometry,Climate zone and HVAC type the rest left at default values.It ran and gave me an IOError i posted the advanced output below it may help.
I thought maybe it has some sort of permission problem so i tried to run it i get this error and i have no idea what to do:
Error:SWIG the application using command line using
sudo /usr/local/openstudioapplication-1.8.0/bin/OpenStudioApp
but i encountered the same problem.
```Standard Output:
val=1
[openstudio.measure.OSRunner] SWIG director method error. IOError: not opened for reading
I'd appriciate any helpreading
Traceback (most recent call last):
:/ruby/3.2.0/gems/openstudio-standards-0.6.1/lib/openstudio-standards/weather/information.rb:198:in each'
:/ruby/3.2.0/gems/openstudio-standards-0.6.1/lib/openstudio-standards/weather/information.rb:198:inget_standards_weather_file_path'
:/ruby/3.2.0/gems/openstudio-standards-0.6.1/lib/openstudio-standards/weather/modify.rb:175:in model_set_ground_temperatures'
:/ruby/3.2.0/gems/openstudio-standards-0.6.1/lib/openstudio-standards/create_typical/create_typical.rb:410:increate_typical_building_from_model'
/home/tomer-gigi/BCL/3ecef6eb-ae4e-48da-b955-594e44b546bf/a74d53b6-6d8b-4b99-940e-008923731568/measure.rb:222:in `run'
[openstudio.workflow.OSWorkflow] Found error in state 'OpenStudioMeasures' with message: 'Runner error: Measure '/home/tomer-gigi/BCL/3ecef6eb-ae4e-48da-b955-594e44b546bf/a74d53b6-6d8b-4b99-940e-008923731568/measure.rb' reported an error with [SWIG director method error. IOError: not opened for reading
/home/tomer-gigi/BCL/3ecef6eb-ae4e-48da-b955-594e44b546bf/a74d53b6-6d8b-4b99-940e-008923731568/measure.rb:222:in `run']'
Standard Error:
Failed to run workflow. Last Error:
run.log:
[10:25:22.951988 WARN] [openstudio.workflow.OSWorkflow] No valid weather file defined in either the osm or osw.
[10:25:25.669557 WARN] [openstudio.standards.CreateTypical] Could not add loads for Plenum. Not expected for 90.1-2004
[10:25:25.684382 WARN] [OpenstudioStandards::Construction] Requested U-value of 0.58 for Typical Insulated Exterior Mass Wall is too low given the other materials in the construction; insulation layer will be removed.
[10:25:25.698342 WARN] [OpenstudioStandards::Constructions] Can only set the u-value of opaque constructions or simple glazing. U 0.88 SHGC 0.16 Sgl Ref-A-L Clr 6mm is not opaque or simple glazing.
[10:25:25.706419 WARN] [OpenstudioStandards::Constructions] Requested U-value of 1.1686635536297982 for Typical Overhead Door is greater than the sum of the inside and outside resistance, and the max U-value (6.636 SI) is used instead.
[10:25:25.708749 WARN] [OpenstudioStandards::Constructions] Can only set the u-value of opaque constructions or simple glazing. U 1.98 SHGC 0.36 Sgl Ref-B-H Clr 6mm is not opaque or simple glazing.
[10:25:25.717187 WARN] [openstudio.weather.Model] Could not locate the .epw file, cannot get ground temperatures from the associated .stat file.
[10:25:25.717201 WARN] [openstudio.weather.Model] Could not locate the .stat file. Looking up default values based on the climate zone.
[10:25:25.722148 ERROR] [openstudio.measure.OSRunner] SWIG director method error. IOError: not opened for reading
[10:25:25.722344 ERROR] [openstudio.workflow.OSWorkflow] Found error in state 'OpenStudioMeasures' with message: 'Runner error: Measure '/home/tomer-gigi/BCL/3ecef6eb-ae4e-48da-b955-594e44b546bf/a74d53b6-6d8b-4b99-940e-008923731568/measure.rb' reported an error with [SWIG director method error. IOError: not opened for reading
