My model has a lot of unmet load hours, but the simulation fails when I apply the Unmet Load Hours Troubleshooting reporting measure. Here is the link to my .osm file. https://drive.google.com/file/d/1cwh17U-M5ItVbgHZBcCBvIiTw5oxC6KF/view?usp=sharing
Here are the error messages I receive.
Found error in state 'ReportingMeasures' with message: 'Runner error: Measure 'C:/Users/DARIUS~1/AppData/Local/Temp/osmodel-565e-2c55-775f-1946-1726977606-0/resources/measures/UnmetLoadHoursTroubleshooting/measure.rb' reported an error with [SWIG director method error. NoMethodError: undefined method `iddObjectType' for nil:NilClass
This error message appears after it gathers reports.
stderr: Failed to run workflow. Last Error:
stderr: Found error in state 'ReportingMeasures' with message: 'Runner error: Measure 'C:/Users/DARIUS~1/AppData/Local/Temp/osmodel-565e-2c55-775f-1946-1726977606-0/resources/measures/UnmetLoadHoursTroubleshooting/measure.rb' reported an error with [SWIG director method error. NoMethodError: undefined method iddObjectType' for nil:NilClass
stderr: Traceback (most recent call last):
stderr: C:/Users/DARIUS~1/AppData/Local/Temp/osmodel-565e-2c55-775f-1946-1726977606-0/resources/measures/UnmetLoadHoursTroubleshooting/measure.rb:165:inunmet_hrs_from_slave_zones'
stderr: C:/Users/DARIUS~1/AppData/Local/Temp/osmodel-565e-2c55-775f-1946-1726977606-0/resources/measures/UnmetLoadHoursTroubleshooting/measure.rb:517:in block in run'
stderr: C:/Users/DARIUS~1/AppData/Local/Temp/osmodel-565e-2c55-775f-1946-1726977606-0/resources/measures/UnmetLoadHoursTroubleshooting/measure.rb:512:ineach'
stderr: C:/Users/DARIUS~1/AppData/Local/Temp/osmodel-565e-2c55-775f-1946-1726977606-0/resources/measures/UnmetLoadHoursTroubleshooting/measure.rb:512:in `run']'
Simulation failed to run, with exit code 1
I appreciate any insight anyone can provide! Thank you.
