Hi, I'm working on a peak demand analysis where I realized there is an inconsistency between what html output vs what 8760 breakdown shows. It looks like table just sums the peak demand values of each end use category, however 8760 results did not confirm those outputs. Even though peak date was same and off with 1 hour, results were not consistent for majority of the categories. I will appreciate if anyone has seen this behavior before or is this a bug in e+ 9.4.
