Hi everyone,
I am new to the OpenStudio tool and currently having issues establishing a connection between the HVAC system and two separate thermal zones. The screenshot displays the current setup:
I have set the specifications of the HVAC system to that in my .idf file which has been running correctly. When I run the OS model, I am getting errors regarding the nodes for each zone not being connected to the Air Loop. I am also getting errors stating that the outlet node for the HVAC system is not connected to any zone. Here is a screenshot of the error file:
Does anyone have any advice on how to correct this error?
Thanks!
