Help
page!
Hi there! Please sign in
help
tags
users
badges
ALL
UNANSWERED
RSS
Sort by »
date
activity ▼
answers
votes
12169
questions
Tagged
view
no
answers
no
votes
2024-04-24 05:33:44 -0500
Mariha
Calculation of surface temperatures in the source code
source-code
surface
temperature
8
views
no
answers
no
votes
2024-04-24 05:11:06 -0500
andrefsl
external-shading
4
views
no
answers
no
votes
2024-04-24 04:32:18 -0500
TanPham
openstudio-sketchup-plugin
openstudio
geometry
spaces
energyplus
7
views
no
answers
no
votes
2024-04-24 02:41:30 -0500
NahidhS
i need to create multiple ports (inlet outlet in a stratification tank), using OpenModelica, with building library ver11.0.0
ports
stratified-tank
open-modelica
11
views
no
answers
no
votes
2024-04-23 18:28:46 -0500
Aaron Boranian
Sizing warning outside of sizing period
energyplus
sizing
ideal-loads-air-system
weather-file
design-day
4
views
no
answers
no
votes
2024-04-23 16:22:02 -0500
andrefsl
Overhang and side shades for windows [closed]
external-shading
40
views
answer
vote
2024-04-23 11:22:43 -0500
James_BC
Unable to use ComStock 2024_R1 measures with OS_SDK 3.7
comstock
openstudio-sdk
openstudio-3.7.0
openstudio-standards
19
views
no
answers
no
votes
2024-04-23 10:26:38 -0500
MapMortar
Is HotWaterEquipment available in the UI
openstudio-sdk
openstudio
openstudio-application
district-hot-water
load
12
views
no
answers
no
votes
2024-04-23 05:58:23 -0500
Bedson
Open Loop, Pipework Sizing
openstudio
volume
pipe
plant-loop
14
views
no
answers
vote
2024-04-23 05:53:31 -0500
MatteoMerli
Chiller Heater Modules in OpenStudio
central-heat-pump-system
chiller-heater
plant-loop
openstudio-3.7.0
12
views
no
answers
no
votes
2024-04-22 09:49:20 -0500
Aaron Boranian
radiance measures run-time error
radiance
measures
error
37
views
answer
vote
2024-04-22 03:50:47 -0500
PmP
Cooling Capacity of Air-Chiller Decrease as the Temperature Rises (hottest simulation day)
energyplus
air-chiller
refrigeration-equipment
cooling-capacity
compressor
106
views
answer
no
votes
2024-04-21 12:01:51 -0500
Denis Bourgeois
Simulation Error (OpenStudio)
buildings
construction
errors
openstudio
25
views
answer
votes
2024-04-20 22:31:19 -0500
Ski90Moo
Zone Air Chiller Total Cooling Rate vs Zone Air Chiller Zone Total Cooling Rate
air-chiller
refregeration
warehouse
walkin-cooler
cooling-load
180
views
answer
no
votes
2024-04-20 22:04:46 -0500
Ski90Moo
Is there a way to extract thermal zone and space information to excel?
energyplus
construction
openstudio
summary-report
internal-load
27
views
no
answers
vote
2024-04-19 21:25:24 -0500
vtab
EnergyPlus HVAC power increases after decreasing the heating setpoint [closed]
energyplus-api
heating-coil
dual-setpoint
energyplus
python-ems
28
views
no
answers
vote
2024-04-19 14:58:32 -0500
VHellou
EnergyPlus-HP-VRF-Floor heating/cooling
energyplus
air-to-water-heat-pump
heat-exchanger
floor-heating
refrigerant
34
views
no
answers
no
votes
2024-04-19 12:46:23 -0500
sheida
why my results are not changed after I am changing the numbers for melting and freeing point of PCM
energy
energy-consumption
energyplus
pcm
phase-change-material
70
views
answer
no
votes
2024-04-19 09:18:38 -0500
Aaron Boranian
Creating workflow.osw file in Python
python
openstudio
openstudio-sdk
osw-file
53
views
answer
no
votes
2024-04-18 13:04:03 -0500
rraustad
set point not met for the period of 01/04 - 31/09
energyplus
openstudio
airloophvac
setpoint
26
views
answer
vote
2024-04-18 10:25:04 -0500
shorowit
in openstudio. is the output variable "zone air temperature" dry bulb temperature or wet bulb temperature?
openstudio
58
views
answer
vote
2024-04-18 09:30:30 -0500
James_BC
openstudio-sdk
comstock
71
views
answer
vote
2024-04-18 07:11:49 -0500
Thierry Nouidui
fmpy
energyplus
fmu
error
energyplustofmu
32
views
no
answers
no
votes
2024-04-17 13:55:08 -0500
ag
Evaluating your results for accuracy
quality-assurance
designbuilder
debugging
troubleshooting
47
views
answer
no
votes
2024-04-17 09:20:15 -0500
Luís Filipe S.
HVAC and Daylight error in Designbuilder
designbuilder
hvac
daylight
341
views
answers
votes
2024-04-17 07:16:29 -0500
Zakaria
Refrigerant Thermodynamic Properties Data [closed]
refrigeration
refrigerant
air-cooled-chiller
data
energyplus
625
views
answer
vote
2024-04-17 05:46:34 -0500
Zakaria
PCM Hysteresis input fields illustration
energyplus
please-use-existing-tags
hysteresis
15
views
no
answers
votes
2024-04-17 05:10:46 -0500
Zakaria
Negative values of Peak Melting/Freezing Temperatures for PhaseChangeHysteresis
energyplus
pcm
hysteresis
66
views
answer
vote
2024-04-17 00:58:37 -0500
Mike117
Why do I keep getting a SWIG director method error when I try to apply a measure?
openstudio
energyplus
energyplus-measure
apply-measure
28
views
no
answers
vote
2024-04-16 09:22:19 -0500
Aaron Boranian
How to change/set a schedule connected actuator value in Python API?
energyplus
energyplus-api
python-ems
actuator
python-plugin
5
406
next page »
Careers
Contributors
Tags
energyplus
×14
openstudio
×9
×4
openstudio-sdk
×4
×3
air-chiller
×2
comstock
×2
construction
×2
designbuilder
×2
energyplus-api
×2
error
×2
external-shading
×2
hysteresis
×2
openstudio-3.7.0
×2
×2
pcm
×2
plant-loop
×2
python-ems
×2
refrigerant
×2
actuator
×1
air-cooled-chiller
×1
airloophvac
×1
×1
apply-measure
×1
buildings
×1
×1
chiller-heater
×1
compressor
×1
cooling-capacity
×1
cooling-load
×1
data
×1
daylight
×1
debugging
×1
design-day
×1
district-hot-water
×1
dual-setpoint
×1
energy
×1
energy-consumption
×1
energyplus-measure
×1
energyplustofmu
×1
errors
×1
floor-heating
×1
fmpy
×1
fmu
×1
geometry
×1
heat-exchanger
×1
heating-coil
×1
hvac
×1
×1
internal-load
×1
The
Unmet Hours
and
Big Ladder
Powered by
here is how
dummy
