Help
page!
Hi there! Please sign in
help
tags
users
badges
ALL
UNANSWERED
RSS
Sort by »
date
activity ▼
answers
votes
12163
questions
Tagged
views
no
answers
no
votes
2024-04-23 05:53:31 -0500
MatteoMerli
Chiller Heater Modules in OpenStudio
central-heat-pump-system
chiller-heater
plant-loop
openstudio
openstudio-3.7.0
5
views
no
answers
no
votes
2024-04-23 02:26:14 -0500
Mortar IO
Is HotWaterEquipment available in the UI
openstudio-sdk
openstudio
10
views
no
answers
no
votes
2024-04-22 19:14:42 -0500
James_BC
Unable to use ComStock 2024_R1 measures with OS_SDK 3.7
comstock
openstudio-sdk
openstudio-3.7.0
openstudio-standards
7
views
no
answers
no
votes
2024-04-22 09:49:20 -0500
Aaron Boranian
radiance measures run-time error
radiance
measures
error
6
views
no
answers
no
votes
2024-04-22 07:23:29 -0500
NahidhS
i need to create multiple ports (inlet outlet in a stratification tank)
ports
stratified-tank
33
views
answer
vote
2024-04-22 03:50:47 -0500
PmP
Cooling Capacity of Air-Chiller Decrease as the Temperature Rises (hottest simulation day)
energyplus
air-chiller
refrigeration-equipment
cooling-capacity
compressor
97
views
answer
no
votes
2024-04-21 12:01:51 -0500
Denis Bourgeois
Simulation Error (OpenStudio)
buildings
construction
errors
openstudio
24
views
answer
votes
2024-04-20 22:31:19 -0500
Ski90Moo
Zone Air Chiller Total Cooling Rate vs Zone Air Chiller Zone Total Cooling Rate
air-chiller
refregeration
warehouse
walkin-cooler
cooling-load
131
views
answer
no
votes
2024-04-20 22:04:46 -0500
Ski90Moo
Is there a way to extract thermal zone and space information to excel?
energyplus
construction
openstudio
summary-report
internal-load
25
views
no
answers
vote
2024-04-19 21:25:24 -0500
vtab
EnergyPlus HVAC power increases after decreasing the heating setpoint [closed]
energyplus-api
heating-coil
dual-setpoint
energyplus
python-ems
27
views
no
answers
vote
2024-04-19 14:58:32 -0500
VHellou
EnergyPlus-HP-VRF-Floor heating/cooling
energyplus
air-to-water-heat-pump
heat-exchanger
floor-heating
refrigerant
30
views
no
answers
no
votes
2024-04-19 12:46:23 -0500
sheida
why my results are not changed after I am changing the numbers for melting and freeing point of PCM
energy
energy-consumption
energyplus
pcm
phase-change-material
67
views
answer
no
votes
2024-04-19 09:18:38 -0500
Aaron Boranian
Creating workflow.osw file in Python
python
openstudio
openstudio-sdk
osw-file
49
views
answer
no
votes
2024-04-18 13:04:03 -0500
rraustad
set point not met for the period of 01/04 - 31/09
energyplus
openstudio
airloophvac
setpoint
24
views
answer
vote
2024-04-18 10:25:04 -0500
shorowit
in openstudio. is the output variable "zone air temperature" dry bulb temperature or wet bulb temperature?
openstudio
57
views
answer
vote
2024-04-18 09:30:30 -0500
James_BC
openstudio-sdk
comstock
70
views
answer
vote
2024-04-18 07:11:49 -0500
Thierry Nouidui
fmpy
energyplus
fmu
error
energyplustofmu
30
views
no
answers
no
votes
2024-04-17 13:55:08 -0500
ag
Evaluating your results for accuracy
quality-assurance
designbuilder
debugging
troubleshooting
47
views
answer
no
votes
2024-04-17 09:20:15 -0500
Luís Filipe S.
HVAC and Daylight error in Designbuilder
designbuilder
hvac
daylight
339
views
answers
votes
2024-04-17 07:16:29 -0500
Zakaria
Refrigerant Thermodynamic Properties Data [closed]
refrigeration
refrigerant
air-cooled-chiller
data
energyplus
624
views
answer
vote
2024-04-17 05:46:34 -0500
Zakaria
PCM Hysteresis input fields illustration
energyplus
please-use-existing-tags
hysteresis
15
views
no
answers
votes
2024-04-17 05:10:46 -0500
Zakaria
Negative values of Peak Melting/Freezing Temperatures for PhaseChangeHysteresis
energyplus
pcm
hysteresis
66
views
answer
vote
2024-04-17 00:58:37 -0500
Mike117
Why do I keep getting a SWIG director method error when I try to apply a measure?
openstudio
energyplus
energyplus-measure
apply-measure
openstudio-application
26
views
no
answers
vote
2024-04-16 09:22:19 -0500
Aaron Boranian
How to change/set a schedule connected actuator value in Python API?
energyplus
energyplus-api
python-ems
actuator
python-plugin
43
views
answer
vote
2024-04-16 03:02:19 -0500
Julien Marrec
Is there a reason why I have unmet hours when I have ideal air loads and mostly everything is autosized?
output-report
unmet-hours
energyplus
openstudio-results
53
views
answer
no
votes
2024-04-16 01:09:07 -0500
Mike117
I can not find the zone air inlet node in the library in Openstudio's HVAC tab. It is causing a severe error when running the simulation.
openstudio
energyplus
severe-error
node-connection
149
views
answer
vote
2024-04-15 12:20:42 -0500
Julien Marrec
Status of OpenStudio SDK python bindings
python
openstudio-sdk
reporting-measure
views
no
answers
no
votes
2024-04-15 09:11:41 -0500
brunakevellyn
infrastructure for air conditioning delivered to the finished building but equipment not
hvac
leed
baseline
proposed
air-conditioner
views
no
answers
no
votes
2024-04-15 08:22:22 -0500
brunakevellyn
Infrastructure for air conditioning was delivered to the finished building, but the equipment was not [closed]
hvac
leed
baseline
proposed
air-conditioner
19
views
no
answers
vote
2024-04-15 02:15:43 -0500
PmP
Humidifier "VariableInletWaterTemperature" not working after bugfix and proposal of addition to "Humidifier:electric" (EnergyPlus 9.4)
humidification
energyplus
water-use
bug-report
humidifier
5
406
next page »
Careers
Contributors
Tags
energyplus
×15
openstudio
×9
openstudio-sdk
×5
hvac
×3
×3
air-chiller
×2
air-conditioner
×2
baseline
×2
comstock
×2
construction
×2
designbuilder
×2
energyplus-api
×2
error
×2
hysteresis
×2
leed
×2
openstudio-3.7.0
×2
×2
×2
pcm
×2
proposed
×2
python
×2
python-ems
×2
refrigerant
×2
actuator
×1
air-cooled-chiller
×1
airloophvac
×1
×1
apply-measure
×1
bug-report
×1
buildings
×1
×1
chiller-heater
×1
compressor
×1
cooling-capacity
×1
cooling-load
×1
data
×1
daylight
×1
debugging
×1
dual-setpoint
×1
energy
×1
energy-consumption
×1
energyplus-measure
×1
energyplustofmu
×1
errors
×1
floor-heating
×1
fmpy
×1
fmu
×1
heat-exchanger
×1
heating-coil
×1
humidification
×1
The
Unmet Hours
and
Big Ladder
Powered by
here is how
dummy
