Help
page!
Hi there! Please sign in
help
tags
users
badges
ALL
UNANSWERED
RSS
Sort by »
date
activity ▼
answers
votes
12158
questions
Tagged
views
no
answers
no
votes
2024-04-19 12:46:23 -0500
sheida
why my results are not changed after I am changing the numbers for melting and freeing point of PCM
energy
energy-consumption
energyplus
pcm
49
views
answer
no
votes
2024-04-19 09:18:38 -0500
Aaron Boranian
Creating workflow.osw file in Python
python
openstudio
openstudio-sdk
osw-file
12
views
no
answers
no
votes
2024-04-18 23:17:21 -0500
Mike117
Is there a way to extract thermal zone and space information to excel?
energyplus
construction
openstudio
summary-report
internal-load
4
views
no
answers
vote
2024-04-18 16:29:32 -0500
VHellou
EnergyPlus-HP-VRF-Floor heating/cooling
energyplus
air-to-water-heat-pump
heat-exchanger
floor-heating
node-connection
46
views
answer
no
votes
2024-04-18 13:04:03 -0500
rraustad
set point not met for the period of 01/04 - 31/09
energyplus
openstudio
airloophvac
setpoint
21
views
answer
no
votes
2024-04-18 10:25:04 -0500
shorowit
in openstudio. is the output variable "zone air temperature" dry bulb temperature or wet bulb temperature?
openstudio
8
views
no
answers
votes
2024-04-18 09:53:16 -0500
Zakaria
Zone Air Chiller Total Cooling Rate vs Zone Air Chiller Zone Total Cooling Rate
air-chiller
refregeration
warehouse
walkin-cooler
cooling-load
48
views
answer
vote
2024-04-18 09:30:30 -0500
James_BC
openstudio-standards
openstudio-sdk
comstock
67
views
answer
vote
2024-04-18 07:11:49 -0500
Thierry Nouidui
fmpy
energyplus
fmu
error
energyplustofmu
18
views
no
answers
vote
2024-04-18 02:50:46 -0500
Zakaria
Cooling Capacity of Air-Chiller Decrease as the Temperature Rises (hottest simulation day)
energyplus
air-chiller
refrigeration-equipment
cooling-capacity
compressor
74
views
no
answers
no
votes
2024-04-17 17:42:01 -0500
James_BC
measure arguments for create_bar_from_building_type_ratios [closed]
comstock
openstudio-sdk
23
views
no
answers
no
votes
2024-04-17 13:55:08 -0500
ag
Evaluating your results for accuracy
quality-assurance
designbuilder
debugging
troubleshooting
44
views
answer
no
votes
2024-04-17 09:20:15 -0500
Luís Filipe S.
HVAC and Daylight error in Designbuilder
designbuilder
hvac
daylight
338
views
answers
votes
2024-04-17 07:16:29 -0500
Zakaria
Refrigerant Thermodynamic Properties Data [closed]
refrigeration
refrigerant
air-cooled-chiller
data
energyplus
623
views
answer
vote
2024-04-17 05:46:34 -0500
Zakaria
PCM Hysteresis input fields illustration
energyplus
phase-change-material
please-use-existing-tags
hysteresis
14
views
no
answers
votes
2024-04-17 05:10:46 -0500
Zakaria
Negative values of Peak Melting/Freezing Temperatures for PhaseChangeHysteresis
energyplus
pcm
hysteresis
60
views
answer
vote
2024-04-17 00:58:37 -0500
Mike117
Why do I keep getting a SWIG director method error when I try to apply a measure?
openstudio
energyplus
energyplus-measure
apply-measure
openstudio-application
20
views
no
answers
vote
2024-04-16 09:22:19 -0500
Aaron Boranian
How to change/set a schedule connected actuator value in Python API?
energyplus
energyplus-api
python-ems
actuator
python-plugin
41
views
answer
vote
2024-04-16 03:02:19 -0500
Julien Marrec
Is there a reason why I have unmet hours when I have ideal air loads and mostly everything is autosized?
output-report
unmet-hours
energyplus
openstudio-results
48
views
answer
no
votes
2024-04-16 01:09:07 -0500
Mike117
I can not find the zone air inlet node in the library in Openstudio's HVAC tab. It is causing a severe error when running the simulation.
openstudio
energyplus
severe-error
node-connection
143
views
answer
vote
2024-04-15 12:20:42 -0500
Julien Marrec
Status of OpenStudio SDK python bindings
python
openstudio-sdk
reporting-measure
views
no
answers
no
votes
2024-04-15 09:11:41 -0500
brunakevellyn
infrastructure for air conditioning delivered to the finished building but equipment not
hvac
leed
baseline
proposed
air-conditioner
views
no
answers
no
votes
2024-04-15 08:22:22 -0500
brunakevellyn
Infrastructure for air conditioning was delivered to the finished building, but the equipment was not [closed]
hvac
leed
baseline
proposed
air-conditioner
18
views
no
answers
vote
2024-04-15 02:15:43 -0500
PmP
Humidifier "VariableInletWaterTemperature" not working after bugfix and proposal of addition to "Humidifier:electric" (EnergyPlus 9.4)
humidification
energyplus
water-use
bug-report
humidifier
40
views
no
answers
no
votes
2024-04-14 07:03:21 -0500
Aaron Boranian
Simulation Error
buildings
construction
errors
42
views
no
answers
no
votes
2024-04-13 23:08:36 -0500
Mike117
Is there a best way to implement this loop in openstudio? Loop is provided in an image.
energyplus
openstudio
hvac-control
hvac-loop
138
views
answers
vote
2024-04-13 08:36:54 -0500
BrianLBall
How can I generate an eQuest "parms" equivalent in OpenStudio?
openstudio
equest
parametric-analysis
42
views
answer
votes
2024-04-12 17:42:46 -0500
macumber
OpenStudio SketchUp Plug-in in SketchUp 2024
sketchup-openstudio-plugin
sketchup
openstudio
57
views
no
answers
votes
2024-04-12 14:51:58 -0500
Greg Collins
PV / Battery Storage Algorithms, Open-source software, Python
pv
battery
python
19
views
no
answers
no
votes
2024-04-12 08:52:58 -0500
payam
ASHRAE Library - makes software too slow
openstudio
library
5
406
next page »
Careers
Contributors
Tags
energyplus
×15
openstudio
×10
×5
openstudio-sdk
×4
hvac
×3
python
×3
air-chiller
×2
air-conditioner
×2
baseline
×2
comstock
×2
construction
×2
designbuilder
×2
hysteresis
×2
leed
×2
node-connection
×2
×2
pcm
×2
×2
proposed
×2
actuator
×1
air-cooled-chiller
×1
airloophvac
×1
×1
apply-measure
×1
battery
×1
bug-report
×1
buildings
×1
compressor
×1
cooling-capacity
×1
cooling-load
×1
data
×1
daylight
×1
debugging
×1
energy
×1
energy-consumption
×1
energyplus-api
×1
energyplus-measure
×1
energyplustofmu
×1
equest
×1
error
×1
errors
×1
floor-heating
×1
fmpy
×1
fmu
×1
heat-exchanger
×1
humidification
×1
humidifier
×1
hvac-control
×1
hvac-loop
×1
internal-load
×1
The
Unmet Hours
and
Big Ladder
Powered by
here is how
dummy
