First see if you have a default space type assigned to your building. You can do this by selecting "My Building" in the facility tab as shown on the facility tab documentation..
If you do have a default space type then all spaces will inherit internal loads from this space type unless they have a space type assigned directly to them. You can directly assign a space type to a space by selecting the space you want to assign the empty space type to, then go to "My Model" in the right pane, and drag the empty space type to the "Space Type" drop zone. Now you should only see loads from the empty space type. If you want to add infiltration to that space type then go to the "Space Type" tab and drag in a "Space Infiltration Design Flow Rate" object from the library.
![]() | 2 | No.2 Revision |
