There are a few things to check. First, if your IDF model requests the output variables with the Output:Variable blocks, and at what frequencies (hourly, runperied etc.). In the result collecting section in jEPlus, you need to specify the same frequency as the IDF produces. In your test RVI, you have zone and outside temperatures. Check if they are reported as runperiod in the IDF.
