For those looking still for a answer on this. You need to do it by the use of scripts. In my case I have created one to use inside SketchUp Ruby Command. Here it is what I use:
require 'openstudio'
# Read the open model
model_interface = OpenStudio::Plugin.model_manager.model_interface
model = model_interface.openstudio_model
ground_temperatures = [10.0] * 12 # 12 months, all at 10ÂșC (change it for your input)
site_ground_temp = OpenStudio::Model::SiteGroundTemperatureBuildingSurface.new(model)
site_ground_temp.setAllMonthlyTemperatures(ground_temperatures)
Applying it you will see the following on energyplus default report:
On the other hand I recommend you having a look at CFactor and FFactor boundary conditions. They can be more precise methods for ground surfaces in contact.
Hope it helps :)
