| 4 | No.4 Revision |
Can you try the following:
output_tables = model.getOutputTableSummaryReports
output_tables.addSummaryReport("AllSummaryAndSizingPeriod")
These standard output table reports have been mapped in the OpenStudio SDK since v3.0.0 (2020) - no longer any need to call IDF objects. (tested Tested - works)works.
| 5 | No.5 Revision |
These standard output table reports have been mapped in the OpenStudio SDK since v3.0.0 (2020) - no longer any need to call IDF objects. Tested - works.
EDIT: I hadn't paid attention to the other items in the measure - mea culpa. For instance, this seems odd to me:
def run(model, runner, user_arguments)
super(model, runner, user_arguments)
model = runner.lastOpenStudioModel
The run call has "model" as an argument - what one expects for a ModelMeasure (see here). Yet the runner.lastOpenStudioModel call (what one evokes with a recently ran simulation for a ReportingMeasure) ends up overwriting "model". Hence the measure is modifying the wrong model. So a first move would be to delete (or comment out):
There may be other bits to fix, such as a missing new.registerWithApplication call.
| 6 | No.6 Revision |
EDIT: I hadn't paid attention to the other items in the measure - mea culpa. For instance, this This seems odd to me:odd:
| 7 | No.7 Revision |
EDIT: This seems odd:
The run call has "model" as an argument - what one expects for a ModelMeasure (see here). Yet the runner.lastOpenStudioModel call (what one evokes with a recently ran simulation for a ReportingMeasure) ends up overwriting "model". Hence the measure is modifying the wrong model. model, I think (not tested). So a first move IMO would be to delete (or comment out):
